Virtual thermostat pro - 22°C, no changes
Simone Biagini shared this problem 2 years ago
Hi guys.
I'm trying to setup a test thermostat as termometer (actually without coolong heating etc).
I added Fibaro multisensor, and two triple sensor calculating average values.
Thermostat is showing only 22°C value.. no changes in 24h (but sensors has changed their temperatures normally).
suggestions?
Comments (20)
A manual, a video, a reply.. something to understand how can I get it works.
I'm asking too much?
No Idea. How much did the temperature change for these sensors. Is it possible that the overall temperature change is not worth to change the average temperature?
Good question whether Zipato has completely finished the programming of the virtual thermostat so the average value does work or not. I can imagine that most of people use only last value. This needs to be answered by Zipato.
I also have a thermostat that is not fully implemented and waiting for this. It is Qubino PWM thermostat.
Actually my thermostat is used only as a little test, without heating, cooling etc... only temperature.
I used fibaro motion + 2x Exmotion triple sensor to get an average value.
3 sensors and temp is fixed to 22 after many days.
The same happens with only one (fibaro motion sensor) sensor linked to the thermostat.
All
my sensor updates frequently the temperature, so this is not the issue
source (fibaro update temp every 3hr or if a 1°C change occur). Ezmotion
sensors update temperature every 60min.
The temperature inside the home change a little, but it change. I mean +-1°C in one room, less in another and so on.. but it change. And the thermostat is locked @22.
I tested many setups for my thermostat pro.
I discovered that if I don't add any warmer/cooler device, the temperature device is totally ignored.
If I add at least one device (ex. TKB plug in switch as warmer).. after manually forcing it to on.. the temperature reading become correct!
This is valid only if I use one device as temp sensor, with last value used. If I use multiple devices and average as value.. nothing change and the value stay locked (all sensors have a valid value).
So you mean that only 1 device as temperature meter works? If you add motre and do average, it does not work? Another thing to get fixed?
There are no bugs in calculating average value, issue can occur when one or more thermometer devices linked to thermostat as thermometers does not update their new values for more then half an hour. Average equation will take into consideration only values reported in last 30 minutes when new value is reported. If only one value is reported in that 30 minutes only that value will be used.
Simone, can you change your temperature devices to report every 20 minutes, add an actuator as output and test it?
let us know if this works.
various tests in progress.. I'm unable to understand why sometimes it updates.. sometimes not.
After the firts temperature update, no more changes in temperature.
hello i have the same problem too
thermostat and thermostat pro temp is always on 22 or 5
i does not show the real temp of sesnsors
Hello Simeone,
For example if you are using heating function in your virtual thermostat you can see history of actual temperature values for that thermostat if you go to Device manager - Virtual network - Click on your virtual thermostat - Termostato_HEATING - Termostato_HEATING_LEVEL - ACTUAL - click on tab events.
Frequency of reported values depends on the configuration of thermometers.
Hello Mehrpaad,
Do you have problem with "Average" function as well or in general with thermometer not reporting values to Virtual thermostat?
Value of 22 degress celsius is default value for Virtual thermostats until they receive new values from thermometer.
temp report interval works well ...i have real temp on my thermostat but it does not work on beta application
Hello Mehrpaad,
If you have issues with beta application only, please describe your issue in details on the application community: https://plus.google.com/u/0/communities/107959331935751006364
This topic was about calculating average values in virtual thermostat.
Hi.
Probably I discovered the issue source (not 100% sure).
If you create a thermostat for test purpouses, with temp surces but without heating or cooling devices.. the thermoste not update the temperature (u are unable to find that in the device log).
If you add heating/cooling devices (I used a simple dummy virtual switch to test) the thermostat start to update the temperature, and this could be seen in the device log too.
take a look.
hi simone
i selected the cool and heat device
our problem is with the firmware
but thanks for help
i have same problem. i have setted a lot of virtual thermostat for open and closes cooler valve buttt some thermostat do not update temperature value and do not open and closed valve
solved. i try and see that wheen i add a new virtual thermostat pro if i add first temperature sensor all work fine but if i add first switch, temperature do not change and stay fixes on 22 degrees
I have the same problem. The solution of roberto did not solve the problem here. I am using the multisensor 4-in-one from Zipato.
Same issue. Can anyone from Zipato elaborate on this?
this is an issue that was 2 years ago and it's fixed a long time ago.
The issue that your controller could have is that when you don't define a thermometer in the thermostat itself, the default value is shown, which is 22 degrees.
If you have any other issues submit a ticket and send us your serial for an eventual check.
Best regards
Comments have been locked on this page!
