Weather comparison (Rain forecast)
Ubuntuu shared this thanks 16 months ago
I would like to create a rule that is dependent on the actual weather or the weather forecast.
I want to run a rule if the weather forecast does NOT predict rain in the next (at best 3) hours.
Any ideas how I can manage that?
I only have the virtual weatherstation at the moment and the nearest thing for that would be the PRECIPMM I guess, right?
Thanks in advance!
Comments (5)
/Am7pHgz2Anjuqko1N0WQgw5kvx2KcObTq+eaBztVRP3qE8T9jC4G7JJGbZgAAAABJRU5ErkJggg==
something i have had running for some time and works.
Though with a 3 hr window it may be difficult. You will also need to check how often your weather station updates its information.
Do you update the rain data correctly? In my case there is no rainfall data, the rest of the data of the virtual weather station works correctly, but does not provide rain data.
Os actualiza correctamente los datos de lluvia? En mi caso no hay datos de precipitación, el resto de los datos de la estación meteorológica virtual funcionan correctamente, pero no aporta datos de lluvia
With the old "WEATHER" virtual device it worked fine (2 day rain forecast). However, with the new "WEATHER" (Yahoo) rain does not work. It' a pity.
Now, I use IfTTT instead.
Que servicio empleas para la previsión de lluvia?
