Weekly scheduler is not working!
Aviad Belulu shared this thanks 11 days ago
I have create a simple rule:
(see images)
When => Scheduler Weekly (every day at 20:00) - never ends
then -> Action on "zipato mm motor control" -> GOTOVALUE 0
and then "Synchronize rules" (successfully)
It is not working no matter what I configure in weekly.
However, If I change it to minute (for example) -> IT IS WORKING!!!
Comments (2)
Have you synchronised devices (circular arrows button on the left) as well as synchronising rules (up/down arrows on the right)? The two are not the same (confusingly). I think, for schedulers, you need to do both (or at least synch devices).
Also, don't reuse schedulers by dragging them from other rules. This seems to cause problems. Always create a new one from scratch.
Finally, it seems to take a while for schedulers to get going. Leave it for a day and see whether it starts working.
The system is full of traps for the unwary.
I did it all by the book.
After debugging it I find out it was the seller problem and his configuration was wrong.
I fixed the configuration and it is now working.
Thank you!
Thank you:)
