What are "Safety Sensor" and "Panic Button" into Zipatile built-in sensors?
Sergio shared this thanks 6 months ago
Can you please explain what are for "Safety Sensor" and "Panic Button" in the internal IP of ZipaTile?
Comments (4)
Safety sensor is for the Safety alarm partition. It detects when the power is out and the Zipatile is running on battery power. The Panic sensor is usually programmed into the bottom right touch button on the Zipatile as a panic alarm button. It set off the alarm on the Zipatile.
Adrian, is this correct? My understanding is that the System alarm partition is the one that is triggered if the mains power goes out. In the Zipatile's user's guide, the Safety alarm is supposed to be a preconfigured alarm that is triggered when the built-in noise sensor senses noise at level 7 for more than 15 seconds (which by the way, I have not been able to get it to work).
this sensor can listen to a smoke detector in the house and thus issue an alarm
Safety sensor is linked to an internet disconnection alarm, the panic sensor is a panic alarm that is pre co figured to be trigered by one of the zipatile touch buttons (bottom right)
