an easy way to control dimmer rgbw bulbs at once
With all the new dimmable rgbw bulbs on the market from Zipato/Osram/Hue/Fibaro/Aeonlabs, should there be an easy way to group all the bulbs together and have them match each other state.
I had Zipato add some attributes for the Osram Lightify bulbs, but now notice that these attributes are not present in the Fibaro RGBW puzzles. How to match them?
There really should be an easy group function and puzzle for these as every other system has.
A When block with a rgbw sensor any, that matches the groups settings to the one bulb setting. This really should be a no brainer. Also while i'm at it, where is the option to turn on/off the rainbow function for these bulbs/modules when you want it. Not via the parameter, which makes it permanent. Again, every other controller has this option. Grrrr, another rule that is 3 pages long to accomodate a simple task.
