Sunrise scheduler bug
            I think I've found a scheduler bug. If you create a rule with a scheduler and specify sunrise, it's then impossible to get rid of the sunrise setting afterwards.
Repro:
1) Create rule with scheduler set to daily and sunrise. Synch, reboot.
2) Go back to the rule and remove the sunrise setting to leave an ordinary time. Save, synch. The change appears to have been saved.
3) Reboot. Go back to the rule and the sunrise setting is back again!
The only solution is to remove the scheduler and set up a new one.
The worst thing about this is that it's easy to miss and so it causes you to waste time wondering why your rule isn't working.
