Qubino smart meter and relay
Hi, I bought the rail mounted Qubino Smart Meter + relay , but it does not seem to work within the Zipato environment. I managed to include it into the network, but the metering does not work and I also have no way of activating or deactivating the relay.
Does anyone have a solution? ANybody can help by any chance?
Interested in this topic, as I am about to install the one just received!
I also left a message on Qubino's support, for I don't think a lot of people have this equipment yet. Did you buy the relay too?
I have several Qubino devices and all work. I have Qubino Flush 1 Relays, Qubino Flush 1D Relays, Qubino Flush 2 Relays and Qubino Flush Shutters. All of them are meters, which one you have?
At the beginning I had problems to include it but once I got the handle on Qubino devices it all went good. The only device that has compatibility issues is the Qubino Shutter, it does not report values for current consumption and also Zipato does not support the Benetian Blind Mode (the interface does not allow you to tilt the blinds).
Hello Zipato, this topic has been categorised as "Known". What does it mean? Is Qubino smart meter supported? Thanks for your feedback
Hello Eric, all,
I managed to include the Qubino Smart meter and it works ok with Zipatile. But:
* Power Reactive (var) is missing
* Power Reactive cumulative (Kvarh) is missing
* I have not tested yet the external relay function, but I pretend to
For the two missing measurements I have opened a ticket and I am waiting for an answer.
Regards!
Hello Eric, all,
Regards!
Hi Pablo,
I have included mine and it works fine. I can display 6 measurements:
Cumulative consumption (in kWh)
Cumulative consumption (in kVAh)
Current Amps
Current consumption (in kWh)
Current power Factor (I don't know what it is!)
Current voltage
My relay still does not work, but the guy from Qubino told me to create a parameter (see below), then to exclude ad reinclude the meter. I'll try that tomorrow as I am not on the premises today. I'll keep my fingers crossed!
Procedure to get the meter to recognize and pilot the relay (not tested yet)
Hi Pablo,
Current Amps
Current voltage
I know for a fact that one of the installers tried this parameter change, exclude and include via Fibaro Home center and it did work. at the reinclusion the device had another endpoint as relay and it was working fine.
Hi, I can't include the smart meter using my zipatile.
The discovery for exclusion starts, a device is found but the countdown drops to zero and the process fail...
How did you manage to exclude/include the device?
I tried to press the s button for 2 seconds, then for more than 6 seconds, I also tries to get very close to the device but no luck.
The green led on the meter is blinking green fast.
Anyone coul give me a suggestion?
A ticket is already open.
My ticket is open too...
In the meantime I also asked Qubino for support, but it seems that they have no solutions to provide.
Let's wait for an answer from Zipato...
