Connecting / installing modules to ZIPABOX
Daniel Kadlec shared this question 8 years ago
Hello, I have several modules like ZIGBEE, 433MHz, SERIAL, P1...
Is there any right order to be used for installing/connecting that modules to ZIPABOX?
In the instructions for 433 and SERIAL modules is written: Module must always be installed in expansion slot 2 of Zipabox
Thanks in advance
Notice: This device is meant for mounting only with Zipabox. 433MHz Module must always be installed in expansion slot 2 of Zipabox. If you have other module already connected onto slot 2, you can connect 433MHz module on it. Other modules can be attached to 433MHz module.
Notice: This device is meant for mounting only with Zipabox. ZigBee Module must always be installed in expansion slot 2 of Zipabox. If you have other module already connected onto slot 2, you can connect ZigBee Module on it. Other modules can be attached to ZigBee Module.
There is no particular order. But for these communication modules you should use right side of Zipabox (Slot 2), and you should not use more than 3 modules on one side.
Left side (Slot 1) is used for Backup module, Security module and Power module. Eventually you can try Serial module.
Thank you Sebastian for your reply and explanation. However in reality 433 MODULE works only as first one connected to SLOT 2. I'm not sure if ZIGBEE yes, as so far I was not able to connect any ZIGBEE device... Be honest it is very frustrating... I really liked your product, in compare to FIBARO GUI (i'm using it at my another house) but get it work really takes ages... whatever device I buy, doesn't work properly. And this was not really the case of FIBARO...
Best regards
Daniel
