Ubiquiti USG Firewall
            Hi, after i changed router my zipabox have problem with the internet connection.
I have added port forward for TCP: 80, 443, 8080, UDP: 9017 as listed:
https://community.zipato.com/knowledge-base/article/my-zipato-controller-is-offline-what-to-do_2
But with no luck. It works with my old asus router.
Any suggestions? Are there some other port?
I think you have misinterpreted the instructions. It says they need those protocol/port access to the cloud, i.e. goibng out from your network to the internet. You do not need to open or forward any ports inside of your LAN. I'm using Ubiquiti ER-X and it works just fine.
Maybe enable UPNP on the box. This may not help as it is not a requirement to have UPNP enabled.
Now its more confusing i have connection at the evenings for some time :)
(Now with Firmware 1.3.12)
I still can't get it working, any ideas?
