Fibaro FGD 212 dimmer in the rules
Laurent Da Col shared this question 8 years ago
Can you explain to me how to use a Fibaro FGD 212 dimmer in the rules ?
I would like to trigger a rule when using the S2 output of the dimmer.
As far as I can see, you can't use S2 in the rules. You can set a binding, which might be good enough to do what you want if you're very lucky. You can use the second switch of Qubino modules in the rules.
Thanks for your help. I'me going to try a binding...
