Hotel Room motion activated light and manuel on/off ligh combination
Hi there,
I'am trying to setup smart room for our hotel. What i am trying to do is ;
1) the lights(philips hue bulbs) will turn on when the hotel customer enter the room with motion sensor
2) whenn customer turn off the light from zipatale before the sleep i need to keep lights off until the lights will turned on with zipatale again.
3) After the lights on with zipatale again, motion sensor starts on/off the lights again.
how can i create a rule like that?
thank you!
Hello Erkan,
you will need to use Variables for that. You can simply create one variable "sleep" and set this variable to "true" whenever user uses Zipatile to switch off the light. The same variable you should set to "false" whenever user uses Zipatile to switch the light on.
In another rule which is managing your light based on motion sensor event, you should add IF condition such as "IF VARIABLE "SLEEP" IS "FALSE".
If you can't manage this alone, you can always use our Professional services so some of our engineers will connect to your controller and make these rules.
Hello Erkan,
