Dimmer contol is weird
What is happening whit my dimmer control? Qubino dimmers i have one fibaro dimmer that works perfect
pleas look at the video.
IMG_2730 (1).mov
most likely, even though the controller is showing as online, there is a communication issue between the cloud and the controller itself. Could be server issue.
The lichts are responding on the commands. the feedback is nog correct
Hi Lars. I have same problem on any qubino dimmer i have tried. I would say this is a common issue with all qubino dimmers.
Adrian, this is nothing to do with cloud status if the box.
Perhaps raise a support ticket as zipato will need to review the descriptor and fix. Somewhere on other community i have found that someone was told by cubino that this problem is due to multilevel assotioan not being set up correctlyat inclusion. I have tried it by assotiation all endpoints of qubino with the gateway but it did not help.
I have 2 Fibaro dimmers thy work fine...
Zipato answer:
it's a known issue in a cluster. Should be resolved as soon as possible. The dimmer itself should work normally and send correct levels to the device itself though.
Kind regards,
Borna
Zipato answer:
Kind regards,
Borna
Ok. I also reported this to Zipato. I§m not on cluster but as mentioned I also have this own behavious regardless of which firmware revision I use.
