Micromodule switch double toggle
Liam oliphant shared this question 8 years ago
just installed loads of micro switch doubles into my home and cant figure out how to get them working on an egress button I.E. I press once the light comes and stays on then I press again and the light goes off. Please help as this is really annoying and should be more user friendly than this. thanks
you need to change the congratulation of the button type to momentary. see attached pics for step by step.
Or, Go to myzipato and log into control center
click on the device manager tab
click on z-wave
click on the settings icon next to your z-wave device
click on configuration tab at top of bar
here you should see several options. One of them will be button type.
Click on the drop down menu, select momentary.
now click on the label button type, another mini menu appears below it. click send.
