How do I disable the motion/PIR sensor in Zipato Quad Sensor?
carntzen shared this question 8 years ago
I´m trying to disable the motion sensor in my Quad sensor, without luck.
The manual says that configuration option 3 should be set to 0 in order to disable PIR. Even though I´ve set this to zero it is reporting motion (and flashing lights in the same room on and off when motion detected - which is what I´m trying to prevent).
