Creating rules with fibaro dimmer 2
Hi!
I'm trying to create a rule in the rule creator using a Fibaro Dimmer 2, but I can't find button 1 or 2 under "control".
I can see them under "actuator" and "meter" and even under "sensor" but not under control.
I have an older fibaro dimmer (211) that shows up fine.
What am I'm doing wrong? I've turned of secure inclusion and I can create working associations using the association manager, etc.
regards,
Johannes
Have you upgraded firmware since you last added your dimmer (the one that shows up fine)? If that is the case it might be an issue with the descriptor on the newer firmware.
One issue that it might bee is that I was running the beta version of the firmware, I downgraded yesterday and I'm going to re-add the dimmer and see if I can get it to work.
I tried submit a ticket but only got a response that Zipato not are helping out without me paying them..
