Micromodule switch double
Just installed some micromodule switch doubles into my sockets at home but can't get them on monostable. Basically I go to change the switch type on the module and by standard it has a (2) but I want monostable. Every time I chose monostable and save and refresh it keeps reverting back to (2) almost as it isn't saving my setting. Yes I have tried removing and adding again. Any ideas? Thanks
you need to send the configuration to the module, not save. Click on the name of the parameter you are changing, in this case switch type, then you will see a mini menu open up underneath the parameter setting, send/retrieve/cancel, once you have selected the setting to change click send.
