Micromodule switch double
Liam shared this question 7 years ago
Just installed some micromodule switch doubles into my sockets at home but can't get them on monostable. Basically I go to change the switch type on the module and by standard it has a (2) but I want monostable. Every time I chose monostable and save and refresh it keeps reverting back to (2) almost as it isn't saving my setting. Yes I have tried removing and adding again. Any ideas? Thanks
you need to select "send" There is a menu that is you click on the name of the configuration (in this case "switch type") that open up under it Send/receive/cancel. You need to click send. Afterwards you can click retrieve to see if the parameter has changed.
/wMcI2nbm8zmSAAAAABJRU5ErkJggg==
