Issue about low consumption
Hi there,
I'm using API GET /power-consumption/{attribute} to get consumption of Double Switch device.
I'm use aggregation=MINUTE and period=5 (I want to get consumption every 5 minutes)
I have an issue when I use low power consumption device. I'm using a fan. I just get 0.00 kWh every 5 minutes. But when I check with aggregation=HOUR, the consumption is 0.01 kWh.
How can I get the data low. Eg. 180 joule or 0.00005 kWh
Thank you
