Energy consumption Zipatail
Energy consumption option does not work. The graph displays only for one month. It itself deletes the data. The display of the Dean consumption costs shows the window and shows no data for display. Contacting the suport with tickets is not a response because the most definitely option does not work at all. So buying an option is throwing money away. I spent a lot of time with the problem of wifi connection because Zipatail itself turns off wifi and then needs to restart it to reconnect. With Zipatail I am very unhappy and I will return it to the seller back
I am not sure if any other zipato users have a good solution for this yet, but the inbuilt Zipato energy monitoring solution you can buy has never worked properly as far as I know. Getting individual devices energy reports aren't so bad though.
if you want a hub with a good energy monitoring solution I would suggest Fibaro HC2, though this would involve using only z-wave fibaro modules in your system. Or add a Smappee (or similar) controller to your home.
At the very least you could try just exporting the individual device data yourself into a google speadsheet yourself via IFTTT or http posts. Not user friendly I know, but a solution.
