Remote dual relay switch
Bojan Dojčinović shared this question 7 years ago
Hello
I have a zipato smart home system installed for two years now. In my bedroom I have shutters controled with smarthome and a wall switch. They function excellent. However I would now like to install additional system of shutters also powered by electromotors. The first system was set up with two zipato shutters build in wall switches. I would like to avoid aditional construction work in order to pass another cable for the other set of shutters. Is it possible to put a remote switch outside and connect it to z wave so that it switches power from shutter1 to shutter 2 through smarthome home system controll. I found on web dual relay switch by fibaro but i'm not sure can it be used or if you have any other suggestions. Thank you.
Yes, of course. You can simply use the association/binding configuration for the 2 modules. This way, whenever 1 module is told to open/close the motor, it send a direct signal to the 2nd module to do the same.
This way they do not have to be wired together, or even wired into a wall switch.
