Re-executing the KNX procedure
Kamil shared this idea 6 years ago
Which rule should be used when a 1 bit object comes from the KNX bus only with the value OFF. In zipabox, this object does not change the value and the rule is not retried. I mean roller blinds control via two 1 bit up / down and stop objects
