sauvegarde des règles
jean marc girard shared this question 6 years ago
Bonjour à tous
Suite à panne totale sur Zipamico et avant de flasher la microSD pour réinstaller le logiciel,
je voudrais sauvegarder les règles créées avant la panne.Sont elles sur le cloud ? sur la carte SD ? quel moyen de sauvegarde utiliser?
Cordialement
Controller Backup stores your current image of the controller. That means that all your devices, rules, settings, etc. will be stored on the cloud and you can get them back whenever you want.
Process:
1.) First, make sure you have Backup License (1-year) and that you upgraded everything via Web UI
2.) Open Controller settings
3.) At the bottom of Controller settings you will see the Controller Backup option
4.) Here are the options that are available for backup:
- Create backup: this option creates a backup of your controller
- Select backup file: is an option that shows all your backups
- Details: shows a description of your backup
- Restore backup: is an option for restoring a selected backup
5.) To create backup press Create backup
6.) Add a description to your backup, press SAVE and confirm
7.) Wait around 10-15 minutes to be sure that the backup is done, depends on the number of devices on your controller
8.) Sync
Restoring:
9.) To restore a backup, pick the backup from the drop-down menu, and select desired backup
10.) When you press on desired backup, press RESTORE BACKUP button
11.) Your controller will reboot, and your backup will be restored
12.) After it's done, press SYNC
Kind regards!
