System Change
We were wondering about Zipatile1 can be run as master server? We would like to transfer old system to the new - my3.zipato.com.
Thanks in advance.
Zipatile1 can be the master server on the v3 platform so you can migrate it if you want to.
Kind regards
Kind regards
Should we delete the whole system from my.zipato.com and add server and devices to new system?
Best Regards.
Best Regards.
The procedure to transfer your v2 controller to v3 is as follows:
1. Unregister your controller in v2 platform (Clear owner option)
2. Create v3 account at https://my3.zipato.com/zipato-web/app2login - it is possible to use the same account from v2
3. Under my3.zipato account create System
4. Add server (controller) from step 1 to the System as a Master server - NOTE: Master server can be any Zipato controller but NOT ZipaBox1
5. Add another server to the system as Slave server (Multisever license is required) - optional; NOTE: Slave server can be any Zipato controller.
6. All real devices from v2 will be presented in the System
7. All virtual devices, Scenes, and rules should be re-check by user and re-created if necessary (it is not supported transfer virtual elements from v2 to v3)
8. Upgrade fw to the latest beta version
Thanks a lot for such a brief and detailed explanation.
Best Regards
Best Regards
