Sensitive of fibaro smoke sensor
Mariusz Zajączkowski shared this problem 5 years ago
In Progress
I change the sensitivity of the smoke sensor in the settings from the application, save, enter again and there is no change. Does not save changes to the sensitivity setting. Why?
Did you send new configuration parameter by click on Send button?
Thank you for an answer. Where the send button is ?
when you open configuration parameter dialog menu. On webUI just click on its title, in the mobile app open its input dialog screen.
/fb36895155e9c4ad81b3210cbf886e69
/66a0f5539c6ad0c2c39c99db22b86a99
In my webUI there in not send option
Like in send.docx
ok I found
Click on parameter title and adfitional menu with buttons will be shown
But it doesn't work. I am sending new parametr and then i wake up sensor pres save and there is sill old parametr.
if you have a particular issue with your device, please submit a ticket and Zipato support team will check it remotely.
Yes ofcourse I did.
