Configuring Fibaro shutter 2
Recently purchased a Fibaro shutter 2 module to control roller shutters, trying to see if I can setup a rule to simply put them 'up' or 'down' via an app, controlled by physical switch at the moment. Only way I can find to control them is by sensor.
I use a Qubino Shutter which must be quite the same approach for the application.
Need to use the "SET" bloc and choose to fix the position. To open/close simply give 0 or 100 as input (its a percentage)
Hope it'll help you
Regards,
Hope it'll help you
Regards,
