Master Server offline?
Completed
Today my Zipatile tells me that "Master Server is offline"
But if I check the du devices the cloud server is online but the virtual server is offline? Why?
I thought this is running locally
Still no connection.. Nearly all my rules are not working
I have the same issue!
@tomu My colleague is working on this so please have some patience and it will be resolved.
@Max Mustermann Feel free to open a ticket and we will check it out.
I found the problem, but must be solved by Zipato. It seems to be that a SSL certificate is expired and Zipatile cannot login remotely:
SSL handshake terminated: ssl=0xa11f5c00: Failure in SSL library, usually a protocol error
error:14094415:SSL routines:SSL3_READ_BYTES:sslv3 alert certificate expired (external/openssl/ssl/s3_pkt.c:1286 0xa10feca0:0x00000003)
at com.android.org.conscrypt.NativeCrypto.SSL_do_handshake(Native Method) ~[na:0.0]
at com.android.org.conscrypt.OpenSSLSocketImpl.startHandshake(OpenSSLSocketImpl.java:302) ~[na:0.0]
... 44 common frames omitted
19:50:43.216 [Cloud.scheduler.1] INFO com.zipato.cloud.bootstrap.Boot - trying http://my.zipato.com:8080/zipato-web/remoting/
19:50:43.331 [Cloud.scheduler.1] INFO com.zipato.cloud.bootstrap.Boot - trying https://my3.zipato.com:9443/zipato-web/remoting/
19:50:43.603 [Cloud.scheduler.1] ERROR com.zipato.cloud.bootstrap.Boot - Handshake failed
javax.net.ssl.SSLHandshakeException: Handshake failed
at com.android.org.conscrypt.OpenSSLSocketImpl.startHandshake(OpenSSLSocketImpl.java:374) ~[na:0.0]
at okhttp3.internal.connection.RealConnection.connectTls(RealConnection.java:242) ~[na:0.0]
at okhttp3.internal.connection.RealConnection.establishProtocol(RealConnection.java:200) ~[na:0.0]
at okhttp3.internal.connection.RealConnection.buildConnection(RealConnection.java:174) ~[na:0.0]
at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:114) ~[na:0.0]
at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:196) ~[na:0.0]
at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:132) ~[na:0.0]
at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:101) ~[na:0.0]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42) ~[na:0.0]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:92) ~[na:0.0]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:67) ~[na:0.0]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:93) ~[na:0.0]
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[na:0.0]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:120) ~[na:0.0]
at com.zipato.util.TaggerInterceptor.intercept(TaggerInterceptor.java:14) ~[na:0.0]
at com.zipato.util.RedirectInterceptor.intercept(RedirectInterceptor.java:14) ~[na:0.0]
at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:145) ~[na:0.0]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:179) ~[na:0.0]
at okhttp3.RealCall.execute(RealCall.java:63) ~[na:0.0]
at com.zipato.cloud.bootstrap.Boot.discover(Boot.java:142) ~[na:0.0]
at com.zipato.cloud.bootstrap.Boot.discover(Boot.java:194) ~[na:0.0]
at com.zipato.cloud.bootstrap.Boot.discover(Boot.java:57) ~[na:0.0]
at com.zipato.cloud.bootstrap.Boot.discover(Boot.java:38) ~[na:0.0]
at com.zipato.runtime.Cloud.initServices(Cloud.java:132) ~[na:0.0]
at com.zipato.runtime.Cloud$6.run(Cloud.java:858) ~[na:0.0]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:422) ~[na:0.0]
at java.util.concurrent.FutureTask.run(FutureTask.java:237) ~[na:0.0]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:152) ~[na:0.0]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:265) ~[na:0.0]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112) ~[na:0.0]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587) ~[na:0.0]
at java.lang.Thread.run(Thread.java:818) ~[na:0.0]
Caused by: javax.net.ssl.SSLProtocolException: SSL handshake terminated: ssl=0xa11f5a00: Failure in SSL library, usually a protocol error
error:14094415:SSL routines:SSL3_READ_BYTES:sslv3 alert certificate expired (external/openssl/ssl/s3_pkt.c:1286 0x9c3843a0:0x00000003)
... 45 common frames omitted
19:50:43.615 [Cloud.scheduler.1] INFO com.zipato.cloud.bootstrap.Boot - trying https://54.194.72.219:9443/zipato-web/remoting/
19:50:43.859 [Cloud.scheduler.1] ERROR com.zipato.cloud.bootstrap.Boot - Handshake failed
But I´m wondering why there no more complains here?!? All users with a Zipatile must have this problem..
I saw the error just once for a couple of seconds some time in the last couple of days. So I don't have this issue with my Zipatile 1 (running v3).
I have tons of logs like this. The daily logfile is more than1GB and this every day with the same error message.
Still no solution from Zipato.
Nothing was changed on my Zipatile and nothing was changed in my network.
I have still no solution and nothing works for me since one week. And last comment from Zipato was 4 days ago that I should try to restart it...
Yesterday I started to migrate to Home Assistant (running on a Synology in a Docker container). Now I have at least my roller shutter up and running again.
Actully, my plan was to upgrade to Zipatile 2 in the near future, but in the last 24 hours I made very good experiance with Home Assistant and I like it. E.g. to include Doorbird it takes less than 2 minutes and all features are working (camera, last user, last motion, binary switch).
Same to me today.
Same to me today.
Any solutions for this issue?
