Disadvantages to use slave systems
I've just realized a major disadvantage with using slave system. In my case I have used ZB1 for several years and since one year I have run ZB2 in parallel with only a few devices associated with ZB2. Now when I have registered ZB1 as a slave to ZB2 still have two separate "networks" i.e. the devices mesh are not "helping" one another if they don't belong to the same network (controller). I honestly can't find a good reason to keep my ZB1 as a slave in my system, apart from the obvious, I don't need to re-include every device into the new ZB2 controller. Is there anybody that can find any other advantages/disadvantages to use a master/slave configuration.
large systems where the range is not good enough for a zwave controller
