Alex skills not working 29-01-21
Julius Geeson shared this idea 5 years ago
Completed
My Alexa skills stopped working through Zipabox yesterday (29th January 2021).
I use LightwaveRF lights and a Harmony Hub and Somfy roller blind (433mhz).
The Harmony Hub works through the Alexa skills but the lights and blind don't. They do all work through the Zipato app so I am assuming there is some problem between Alexa and Zipato
Replies (18)
Yes me to
I have the same problem!
Me too!
It was not responding i disabled skill and i tried to link again but linking problem now
Same here, there is a problem
Same here...not working
I have also the same problem.
Is zipato doing something to fix it?
Yes i have the same issue, worked fine for a year until today!
Same problem here ! It stop working yesterday (29th January).
Please fix it quickly, it is used to control lights and roller shutter.
Thanks in advance
Same Problem, the OAuth from zipato.com does not work as aspected.
my.zipato.com work but not https://auth.zipato.com/login.jsp.
possibly a few problems with the authentication via the service.
I was only able to open the forum via google authentication.
we are experiencing some issues with the auth servers.
It will be resolved accordingly.
Please do not try to disable the skills as you wont be able to enable them again before we fix everything.
As soon as we fix it hopefully everything will continue working as before.
We apologize for the inconvenience.
Zipato Team
I disabled my linking now what i am going to do
You will have to wait for us to fix it and enable it again.
Zipato Team
Annoying because I just deactivated my skill before this information 8- (
Nothing will happen, you will just have to enable it again after we fix the issue.
I have already deactivated them as well
No problem, I just wanted you guys not needing to enable it again later.
Same problem here. I didn't deactivate anything :-)
Two different problems with probably one and the same cause
Authentication and connection with alexa are currently possible, but the original problem still exists
It just seemed to take a certain amount of time after the new token until everything could access zipato. Alexa can now control zipato again.
Hello everyone,
we managed to get all services up and running.
We are sorry for the issues!
