Thermostat
Loving the product, unfortunatly I am having the same issue repeatadly.
I have setup a Thermostat with a schedule which is a beutiful solution with different temperatures at different hours, perfect.
However, on many occations the thermostat is switching away from the schedule at "RUN PROGRAM" resulting in cold floors. To fix the problem I open the app and press "RUN PROGRAM" at everything runs as expected again.. until next time.
This problem occurs maybee once every 5-10 days or so, not seeing much of a pattern. But it is often enough to be annoying.
Please help, the wife is not happy.
Regards,
Per
