Device name assigned to fibaro door sensors are disappearing
Carlo shared this problem 5 years ago
Device name assigned to fibaro door sensors are disappearing and going back to default value. Device and names where there from more than a year. Now the whole configuration is a mess with lot of devices with exactly the same name. What happened?
V2 or V3? If V3 you must no longer use the Sync button on the left-hand side, this leads to exactly such problems. Under V3, you may only edit rules and synchronise them via the button on the right-hand side, everything else must be done with the app.
V2, and it happened without any sync or action made from me.
