Get values from a Virtual enpoting in Api v2
I have some Virtual endpoint and I dont have problem to set the values of each one using the API, the problem is when I try to get the values, I dont find any way on documentation to get value1,2,... of one Virtual endpoint.
Now Im using the rest api https://my.zipato.com/zipato-web/rest/meters/<ID> and parse the Json but I thing than the new API must have a better way to get it.
Maybe Im wrong or a not able to find it? Anyone can give me some light on this?
best regards,
First get the endpoint ID :
https://my.zipato.com:443/zipato-web/v2/endpoints
You'll get an <ENDPOINT_UUID> for the device you are looking for.
Second, get the attributs (value1, 2, etc) :
https://my.zipato.com/zipato-web/v2/endpoints/<ENDPOINT_UUID>?attributes=true
You'll get the <ATTRIBUT1_UUID>, <ATTRIBUT2_UUID>, etc
Then, request the attribut value :
https://my.zipato.com:443/zipato-web/v2/attributes/<ATTRIBUT1_UUID>/value
All good :)
You can set a value by POSTing the value only at :
I agree it is heavier if you request it only once, but it is lighter over time.
All good :)
Thank you a lot!
Thank you a lot!
Thanks to both authors for the question and the answer. The API documentation is quite good, yet I was pulling my hair off since this piece of information was missing.
This was just what I needed!
