How to define the green light brightness on a zipabox 2?
chardin shared this question 3 years ago
It was possible on the zipabox 1 but I didn't find this setting on the zipabox 2
1. Click on DEVICE MANAGER
2. Click on SETTINGS of Master server (M)
On the top you will find the green Light Brightness field
Hope it helps
Hope it helps
Thanks for your help but I don't find the field. Do you access to this field by the web portal (with V3 platform) or via the mobile app? Do you confirm that you have a zipabox 2 (and not the first version)?
Perhaps a picture will help to localize this field or an explanation with more details.
My zipabox 2 has the official firmware version 3.0.0.
Thanks. Denis
Hi again, sorry I found by myself the answer. The field is visible if I access by the web portal.
Thanks again for your support.
Denis
I am glad you found it.
Not every web field can be displayed from the mobile application.
By the way, I posted in another post new firmware 3.0.0 was problematic for me as many switches went OFFLINE.
Make sure it's working well for you.
