How Often Should I Use The face Serum?
The frequency with which you should use a face serum depends on your skin type and the specific serum you are using. However, most serums can be used once or twice a day. If you have sensitive skin, you may want to start by using the serum once a day and see how your skin tolerates it. You can always increase the frequency of use if needed.
