i reset the box and all the rules not work
All rules not work
Not a Problem
after a reset all rules not work
You did not create any new rules just before this problem occurred? If yes, please disable them
Did you try to:
-Disable all rules and enable and check them one by one (maybe there is a broken rule that causes issues)
- Create a simple rule with for example a door sensor, motion sensor or schedule?
-Synchronise your rules
Good luck
Did you try to:
Good luck
This is still a problem. There has been lot of instability in rules lately. Sometimes same rule works correctly, and some other time not. Also some previously worked rules do not work anymore. Most annoying is motion sensor triggered rule, which leaves sometimes lights on. Usually at late night, just when you are going to bed.
