local access , pls help
reza shared this question 11 years ago
I am connected to the modem but I do not have local access. What is the reason?47cff0d18eb20bfca3ef0af0b827f10ec31529b0a4ff19d7233c66444ca84f00
Replies (11)
Do you have the latest firmware and APP?
hello Heros
thanks for answer
yes , 0.9.999.4
hello Heros
thanks for answer
yes , 0.9.999.4
I downloaded app from the play Store
the main problem is local connect . mobile phone with zipabox
what do you mean whit local connection?
way do you not use the internet connection whit the server from zipato?
is your internet not steady?
my zipabox is connect via lan cable via adsl modem and my mobile phone is connect with wifi , i have local access but this connection is unstable . means that the moment I have local access and the next moment I have disconnected access .
generally my local access is unstable
I've tested it with different modems and mobile phones, but for all this, there was a problem. Is it problem my zipabox or zipato app ?
thanks for answer
Sorry for the weak in English
What about the web interface? do you have problem whit that also?
i have the box over one year now, and i have had no problem whit connection on the app and the web interface.
My English is also not so strong :)
thanks for answer me dear lars
i dont have problem with web interface . just local access . because i dont have access to internet sometime .so this problem ( local access ) is very great broblem for me :(
Same her! Tried both my networks!
hi
Do you have the same problem?
Never use local connection, i will test it
internet works all the time :)
lars where are u from ?
Netherlands and u?
iran
The best options of Zipato need internet connection....
I know but the internet in iran is weak for us
As far as possible, I should use a local access because internet is weak .
I write rule and learn and setting with internet but for Control of high-speed , I need local access
thank you
