camera issue
Darkwing shared this problem 11 years ago
I have a strange issue. When I try to add an IP-cam using my PC, either with the new or the old dashboard, it does not find any IP-cam and it fails to save when I use IP address.
Though when I then use the app on my android phone, I can easily add an IP-cam as it finds it automatic. Adding is easy and it works perfect. To my surprise I then find a camera added when I log into Zipato from my PC, but when clicking on it, it refuses to show a picture?!
Seems to me IP-camera discovery still needs some TLC on the PC.
Hi Darkwing,
just look into the Setting, maybe you have to add the Stream URL manually.
If you cant see an pictures in the UI, you have to save the Pictures onto Zipato FTP.
A small tutorial you can find here:
http://zipabox.de/ip-kamera-streamt-jetzt-zur-zipabox/
Helle
