How fast is Z-wave, Zipabox, Fibaro together?
Jacob Wiqvist shared this question 11 years ago
Hi all!
I have done som tests and wanted to now others experience and how fast theoretically a relay or light could turn off/on?
My expertness is everything from 0,5-4 seconds before the software have synced and/or the actual relay have turned on or off.
I have also experienced that the switch docent tell the software at all that it is turn on or off and that the software say it is offline!
How fast should the different interfaces react, and how fast does it work if you for example connect to units directly. For example two fiber units? Does this differ depending on unit?
https://www.youtube.com/watch?v=AcLGJOd8470
In this clip it also looks really slow? Is it a software issue, a hardware issue, combined or maybe the actual z-wave standard?
https://www.youtube.com/watch?v=5U7ZYbtolKc
Som more info how it al works would be nice!
Best regards Jacob!
It is fast enough... i think.
its getting slower when the z-wave devises a routed by another z-wave device
Hi.
About 0,3 seconds. Controlled by the iOS app and by a routed device. I guess it can be both faster and slower depending on quite a few parameters.
Regards/L
