Problem whith the buttom 1 and buttom 2 and 433 MHz antenn
Willard Nahlin shared this problem 11 years ago
I have problem whith the buttom 1 and buttom 2
To begin with, I got problems with screwing the antenna for 433 MHz bracket spun around and sat not properly secured in zipato box.
When I opened the drawer see what was wrong because they will aid the entire antenna mount spinning when I skuvade on the antenna.
When I opened the box fell 2 plastic pieces that are positioned in the holes of the buttom buttom 1 and 2 (the third piece of plastic stuck) my problem now is that I do not know how these plastic pieces to be reassembled.
There is a small triangle on one side of the short end that I think will sit on the board because the piece of plastic that is not loose have a small rectangle on the board, but if the triangle pointing left or right, I am very unsure.
Strange that the mount for the 433 MHz antenna was not glued properly in the box?
I had expected a bit more quality on the box mounting details, it just seems to be a little less quality product.
Yes now I need to know exactly how the plastic pieces to be his and not just guess how it was originally.
willard@hotmail.se
