Lamellas controle FIBARO FGRM-222
Davidch shared this question 11 years ago
Hello
I have my house with FIBARO FGRM-222 for my Venetian shutters.
For up and down, it's OK
I'm looking for how to control the position of the lamellas
Anyone have any idea
Regards, David
As long as we don't have a detailed list of what devices are supported we don't know.
But ther could be the same problem as I had. That the unit is not correctly discovered. You need to be wit in one meter of the zipabox when you pair it. You will not get a error message if the unit is correctly discovered.
I have bin told that zwave uses lower power when paired for security reasons.
Ther could be a message of this info when pairing. But that is up to Zipato?
For example when I paired a Nexa dimmer module I used the matching code from Zipato that did not work and gave me a "on off" switch. Then after some Google search I got an answer that I should use an other devices and pair with.
I asked Zipato why I have to use another code, but I have not got any clear answer abut it.
!! out of sujet
Stop drinking
Do you mean subject?
Hey
Facing same issue ... is there a valid answer out there how ich can control the angel of the lamellas. For Fibaro HC there is that option ...
Cheers
