Is the Danfoss Link RS (room sensor) fully supported?
Stefan shared this question 11 years ago
After checking the Knowledge Base and the community questions, I am not quite sure if this device is fully supported by the Zipabox?
My Scenario would be one room sensor in a big living room with two radiators equipped with two danfoss z-wave thermostats (014G0013).
The room sensor measures the actual temperature and compares it to the desired temperature. If there are differences, the sensor synchronizes the two thermostats. As the devices do not "talk" to each other, the
Zipabox box has to control the communication.
The target would be that I only have to change the room sensor and the thermostats will be changed automatically. Or the defined rules of the zipabox do change the thermostats (and the room sensor).
Is this supported?
Kind regards,
Stefan
