Thermometric system
Is possible to have frindly and symple system // ????
example step now is one hour !!!!!!!!!!!!!!!
if i like to start to 8.10 and end to 9,15 is not possible .
as per post
I like set
start from 6,50 to 7,15 (for all week's days) in main system and not in rules
at the moment is not possible and thermometric system if very few fiendly and not
thi is not good interface and not usable
as per post
I like set
What exactly do you want to do? Roberto Kermit
start heating at 06,45 and end at 07,30 for all days
how i can do it ?
inizio riscaldamento alle 6,45 e fine alla 7,30 per tutti i giorni
how i can do it ?
Hey!
Once again an simple and understandable answer! Thanks Ivan
But one thing you must explain, how does a rule work? What do you mean by "check every 15 minutes"?
Kind regards Jacob!
Hey!
Kind regards Jacob!
Hi Ivan thanks for reply
this is good solution and will fix my problem
but you have in zipato native clima widget (as per attached )
and i don't know why has this important limitation: this system (main) is not usable
