Zipato multisensor
Michiel shared this question 11 years ago
The illumination data send from my sensor is too old. The setting that can change this can be set to 30 minutes minimum. According to the manual the sensor will also send out a report with the illumination data when motion is detected or when a door/window opens or closes. However my sensor doesnt change the illumination percentage when motion is detected or the door opens. Is there something I am missing?
if the illumination is the same value it will not be displayed. because it didn't change.
maybe thats why you don't see it.
no problems here with the same sensor.
Thanks for your reply and good to know that there is someone where it works as I would expect it does.
Strangely enough I have the sensor on my desk in full lightning it reads 97%. When I throw a towel over the sensor and activate the motion detector it detects motion but the illumination doesn't change while I am pretty sure that with a towel over the sensor it is not 97% anymore.
how long does it take for changing the values?
I also can noticed no problems with that sensor.
First of all thanks everybody for the replies. I have been working on this tonight and it really doesn't send out the illumination data, it does however send the temperature data when motion is detected or the door is open or closed. Must be something wrong. I will open a ticket as suggested.
