Nexa WBT-912 not detected
David shared this question 11 years ago
Cannot seem to get zipabox to recognize my remote (wall mounted) Nexa WBT-912 switch remote.
I thought it might have been poor connection but I moved the box right next to the remote and it still isn't working... (and it can turn on and off lights 10 meters away from it)
Am I doing something wrong? Is it possible to debug somehow?
This remote now works with the box. Case closed
Replies (6)
What box do you have? Duo or with external 433 module?
Does your box look like on the picture?
Yes it looks like the pictues so I guess its external?
Då är det nog tyvärr så att den inte fungerar: http://wiki.m.nu/index.php/Kompatibilitetsguide_433MHz_och_Z-wave-kontrollers
Se lista
So, I have to say that I was surprised to see the WBT-912 in the zipato settings (see the attached image).
Why is the reason that it is in the settings if it doesn't work?
Then only Zipato can answer why it doesn't work. I hade a lot of problems with the duo box before I got a new external module!
So, should I contact their support or will they answer this question?
Contact there suport! Best thing
