Vision Door Sensor ZD2102 - still not reporting all events
Claus shared this question 11 years ago
Asked earlier - the Zipabox is now located approximately 2 meters from the sensor. No more trouble state but it still only records some events to the web interface and IOS App. Are there other things I need to be aware of here? My log looks like:
STATE Open 17:41:01
STATE Closed 17:41:02
STATE Closed 20:14:29
In between is obviously missing an Open but several other Open/Close events were not registered at all
Any help appreciated
Dear Claus,
It is possible that there are still certain difficulties in communication between the device and controller. Therefore to resolve this issue you need to re-add your Vision Door Sensor ZD2102.
Please let us know if the issue continues.
Best regards
I added two of these sensors about a week ago. One of them also shows up in External sensors category, but the other does not. Both are the same product-id 258(earlier versions had less functionality). I have only mounted one of them on a door, and so far it has reported every open and close AFAIK.
Claus, did the external sensor include as it should when you did the inclusion?
