not showing fahrenheit
Brian Clarke shared this question 11 years ago
I have the backup module which has a temperature sensor built in. However, even though i have fahrenheit selected in the controller settings, it stills displays the temperature in celcius. Is this a known issue? Can it be fixed?
Hello Brian,
please refresh your web UI and check again.
Hi Hrvoje,
I live in the Bahamas and the current
temperature is about 82 degrees, so that is incorrect. Also, if you
switch it to Celsius in the settings you will see that the number does
not change at all. So whether i select Fahrenheit or Celsius, that
number for the temperature is the same. Please check it again.
Mine is also still in Celsius even though my controller is set to Fahrenheit. It shows it that way under the Weather section.
