How do I set up Alarm BEEP on Entry (Zipato siren)
Does anyone know how to trigger a Zipato siren "BEEP" sound during the "Entry time" when an alarm partition is still active.
Using rules, I can set a sound on the Zipato siren for the Alarm "Arm", and "Disarm" but there is no option for "Entry".
As far as I can see, the "SQUARK" function also only seems to work for "Arm" and "Disarm" too.
I want to use a "BEEP" as a reminder to myself that the alarm partition is on - but before it is actually "Triggered"
Any ideas?
Cheers
/Marcus
You could make a rule that when a door opens and the arm is armed >> you could sound a beep then make some sort of loop to check if the alarm is disarmed.
Super idea! I'll try it and let you know.
Thanks HeroS
/Marcus
Thanks HeroS
/Marcus
