Anybody here ever used the Zipato Micromodule Switch Double?
Anybody here ever used the Zipato Micromodule Switch Double? I am thinking about purchasing one but would like to know if you can control each load individually (seeing two separate switches)? Also how is the moduel performance and reliablilty wise?
I have them in use. Yes you will see 2 seperate switches. I have used 433 mhz coco and other z-wave switches(fibaro).
I have replaced all my 433mhz coco by the Zipato Micromodules.
Yes, I have used and installed dozens. No problems thus far. And you can set them up for momentary switches of bistable switches.
great, thanks for the feed back guys. Looking at the wiring template, I have observed the following, let me know if this is accurate, and if i should need any extra copper wiring or other tips:
1. it appears as if the hot line coming from the electrical panel has to go to both the micro module and the physical switches
2. The Load wire going to the lights (two light switches in my case) )will detach from the switches and go into outlets labelled N01 and N02, and the physical switches themselves will plug into S1 and S2.
3. Hot Line and a neutral will be wired into the micro module in L and N respectively.
