PAN08 not work with buttons.
Tomas Garcia Verdugo shared this idea 10 years ago
PAN08 not work with buttons. When the distance is more than 1m.
Anyone know why?
Thank you
Zipato anyone know why?
its german, but try this out for correct cabeling
http://zipabox.de/tag/jalousiesteuerung/
regards Helle
I have the same problem like you. Have you found a solution?
Performing the calibration process as described in the manual.
Also make sure that the phase is connected to the common of the buttons.
If you have more problems let me know.
regards
MOVING RANGE CALIBRATION
It is important to carry out a shutter calibration process before
putting controller to use with your shutters. Press and hold
inclusion button for more than 3 seconds and release before the
6th second, after which Micromodule will start shutter calibration
process. The process is composed of three consecutive stages.
The shutter moves to the TOP in first stage, and to the BOTTOM in
second stage, and to the TOP again in third stage. After
calibration procedure, Micromodule will correctly memorize full
range of UP and DOWN shutter movement.
During the shutter calibration process, if any emergency happens
you can press and release the include button to stop the process.
If shutter movement direction is reversed, this may be caused by
the wrong connection of NC and NO to the motor, please change
NC and NO connection and execute calibration process again.
For safe issue, please select the motor which can stop by itself
when going to bottom end or top end.
