Foscam C1 as Sound and Motion Sensors in Zipabox
Tom Säll shared this idea 10 years ago
Hi, i created a powershell-script to use the Sound and motion sensor on the Foscam as virtual devices so it can be used as a regular device in zipabox. If you got a more elegant solution for this please let me know.. :)
Things you need:
Zipabox
Foscam C1 (might work with other aswell),
Windows computer with Powershell 3 that runs 24/7 if you want your sensors to work all the time.
1. First log in to https://my.zipato.com
2. Open Devicebrowser and click Create new Device
3. Pick Virtual Device, then select Virtual Sensor. Type ex. vSoundsensor and hit Save.
4. Repeat step 2-3 and name the device vMotionSensor instead.
5. Go to the Device Manager or whats its called. the one below the Device Browser. Click on Virtual network and find one of the device you just created. Navigate down the hierachy in the device until you reach STATE. Click on Settings on the STATE
6. Copy the URL in the General-tab of the device and save somewhere on your computer
should look similar to https://my.zipato.com/zipato-web/remoting/attribute/set?serial=something&apiKey=something&ep=something&state=
7. Repeat step 5-6 with the other device you created.
8. Open up you favorite Powershell-editor and create a script with the following content:
while(1){
$current_timestamp=Get-Date -Format u
# change yourfoscamusername and yourfoscampassword
$cam1="http://XXX.XXX.XXX.XXX:88/cgi-bin/CGIProxy.fcgi?usr=yourfoscamusername&pwd=yourfoscampassword&cmd=getDevState"
$rawresult1=Invoke-WebRequest $cam1
[XML]$test1=$rawresult1.Content
if ($test1.CGI_Result.motionDetectAlarm -eq 1){
Invoke-RestMethod -uri "https://my.zipato.com/zipato-web/remoting/attribute/set?serial=something&apiKey=something&ep=something&state=false" | Out-Null
}elseif ($test1.CGI_Result.motionDetectAlarm -eq 2){
Invoke-RestMethod -uri "https://my.zipato.com/zipato-web/remoting/attribute/set?serial=something&apiKey=something&ep=something&state=true" | Out-Null
if ($test1.CGI_Result.soundAlarm -eq 1){
Invoke-RestMethod -uri "https://my.zipato.com/zipato-web/remoting/attribute/set?serial=something&apiKey=something&ep=something&state==false" | Out-Null
}elseif ($test1.CGI_Result.soundAlarm -eq 2){
Start-Sleep -Seconds 3
9a. Now start replace the http://XXX.XXX.XXX.XXX:88/cgi-bin/CGIProxy.fcgi?usr=yourfoscamusername&pwd=yourfoscampassword&cmd=getDevState
XXX.XXX.XXX.XXX:88 with the IP of your cam.
yourfoscamusername is the username to the local webui of your foscam
yourfoscampassword is the password to the local webui of your foscam
9b. replace the https://my.zipato.com/zipato-web/remoting/attribute/set?serial=something&apiKey=something&ep=something&state= URLs with the correct ones from your zipabox and add true of false in the end.
Save and run the script . motion and sound sensor will work until you stop the script. it checks the status every 3 seconds.
To bad its not supported directly from the box!
nice work by the way
After long time traying, I have found a solution for me. It works in the cloud (is is not necessary a activer computer). The answer time is about 12 seconds...
1.-Create an account in IFTTT. Make a rule with the "webhooks" service:
If Send trigger@applet.ifttt.com any email from xxxxxxxemailxxxxx , then Make a web request (cofigure putting the zipato sensor url https://my.zipato.com/zipato-web/remoting/attribute/set?serial=xxxxxxxx&state=TRUE)
2.-In Foscam camera, configure email to send a email to trigger@applet.ifttt.com. (When motion detection)
(in your email account, there will be a sent email with the data, too)
Does that help you?
