Rule malfunctions when editing from second PC?
David Pritchard shared this problem 10 years ago
In Progress
I'm having some apparently random rule failures and I've just noticed that one rule that is supposed to run every 30 minutes, but is not firing at all (I know when it fires because it flips a switch that I put there to test it) was last edited from a second PC, not the PC where I usually edit my rules.
I can't confirm this problem or give more details, except to say that I've noticed that when modifications are made from the Control Center on one PC (and then synched, and the Zipabox rebooted) the Control Center doesn't refresh names or rules on the other PC where you have the Control Center open. You have to reload the application to see the changes. If you forget to do this, make modifications and then synch them, I don't know what sort of mess you might end up with :-)
I suppose one lesson is: don't ever leave the Control Center open.
I'll try to do some more tests and see if I can draw firmer conclusions.
OK since there are some other problems with the scheduler, etc., I'll see if everything works properly when they're fixed.
